<Enter> key Behavior
pmckone
Sometime between version 13.2 and 13.6, the behavior of the <Enter> key seems to have changed. Previously, after the file dates had been compared, and the list of proposed updates were displayed, I could press the <Enter> key to cause the newer files to be copied over the older files. That doesn't seem to work anymore.
pmckone
Thanks for your very quick reply. I should have also mentioned that
the <Up> and <Down> arrows no longer scroll through the list of
directories at the left of the main screen after one directory has
been synchronized. Of course your program can still be controlled with
the mouse, but as you know, programmers like to keep their hands on
the keyboard!
