Been using (and loving) Freefilesync for over a year now without issue
But recently my batch backups are getting the following error and my batch jobs won't run.
"Error Parsing File" Globalsettings.xml and then a row and column numbers
Clicking on that then shows a
"Configuration file Batch.ffs_batch loaded partially only"
I've restup the sync job and batch file from scratch but still getting this error
any help greatly appreciated
cheers eske
Error Parsing file GlobalSettings.xml
Open the file in a text editor and have a look at the given row/cols to see what the problem is.
It looks like the %item_path% bellow
<one>Show in Explorer</one>
<two>explorer /select, "%item_path%"</two>
I can't see anything wrong with this. Can you post the full xml files, both GlobalSettings.xml and your .ffs_batch file that was loaded partially?
here's a screen capture of the 2 error messages, the globalsettings file and the batch files
I don't find any issues with these files, they work fine on FFS 5.11. I think the problem in your case is that you are trying to load these files with an older FFS version.
nice one
thanks
thanks
