Run multiple configurations one by one
mbnoimi
How can I run multiple configurations one by one?
I'm not sure what if this feature exists or not but I don't want to run each configure manually by FFS or by FFS's batch file.
This feature is available in Synkron through "Sync All Tabs" action.
Simply drag-select multiple configurations via the mouse in the configuration panel, then run the combined sync. You can also use CTRL + left mouse click to add or remove individual configurations in the config panel.
