Parallel scan of two (physical) drives
dimko
Hi there,
I have two (physical) drives, C and D, and I sync D to be an exact copy of C.
In the free version I've tried, before the actual sync, it first scans drive C, and then after finishing with it, it scans drive D, and then the actual sync happens.
In the donation version, will it work the same, or it will scan both drives in parallel?
Thanks.
All drives are scanned in parallel; note the "[x threads]".
dimko
You're talking about the free edition as well? Where I can see that x threads? In my case, it first scans the first drive, then the second one, tried it couple of times, every time the same. Should I maybe change some setting?
