Hi, I'm using FFS donor version to manually sync local pc with google drive.
After granting permission to FFS to access google drive, everything works until the next day, but then, reopening and starting the same .ffs profile, FFS crashes (the program does not respond, the mouse shows the spinning wheel) when trying to access to Google Drive files. The only way to repeat the synchronization is to disconnect the Google Drive folder and re-grant the same access permission, each time.
I experienced the same problem on two different computers with two different gmail accounts.
This also prevents me from programming automatic daily synchronizations, because when the batch job starts FFS crashes trying to access the google drive files.
FFS loses access to google drive every day
