Slow transfer
Hello guys im using FFS 13.7 Donation Edition, as you can see on the images my transfer speed 800 byte/second . I have 100 mbps connection. And im trying sync my SSD to Google Drive. It says sometimes 2 day left. Anyone can help? Thanks.
I had the same issue, it seems to simply be copying approximately 1 file per second, so for my backup script I ended up first copying the files I want to a dedicated folder using FFS, then compressing them all into a single 7z file using 7 Zip, and then upload that file to Google Drive using FFS again.
