I accidantaly closed the "tree overview panel" and now I am looking for the possibility to display it again. However I can't find any possibility to re-display the small panels once they are closed.
Maybe I am just to blind to see the obvious...
Please help me! :)
Maybe a toggle menu with the display options (statistics, configuration, tree overview, ...) can be included in one of the next versions.(as part of the advanced/global settings menu)
Thanks!
macroarc
View Options
You can right-click somewhere on the gray area, e.g. between compare and sync buttons, to restore the view or individual panels.
Thank you Zenju!
I feared it would be soooo easy :)
Many many thanks!
Many many thanks!
