HowTo force overwrite of equal = files
miklog
after a storage problem I like to overwrite some corrupted photo files from a backup using the following setup:
left (master with healthy image files) - right (work ssd with some corrupted image files)
I like to copy from the left (master ssd) and force overwrite only those files which are currently on the right (work ssd)
In the setting there is "copy new and updated files to the right" - Is there "overwrite same files to the right?"
Full size https://iili.io/dREyyF9.png
Thanks, Mik
Use comparison variant: "file content"
miklog
Works, thank you for the hint Zenju.
