When I sync with another drive, FFS makes a folder on the drive named RecycleBin*3052.ffs_tmp. The temp file contains 4 folders from the drive I'm copying in my case "My Data, Finance, Quicken, Medical". These files contain 110 GB's of data. Mind you they are in the tmp file created by FFS. So according to the graph once the files are synced from one drive to the other the process should be stopped there, but then it keeps going saying it's moving My Data > RecycleBin*3052ffs_tmp to I don't know where. This process of moving these files (110 GB) takes about 15 minutes to complete.
This never seemed to happen before just in the last couple of months. Has anything changed with your software and is there a way I can stop FFS from creating this tmp folder?
ffs_tmp
viewtopic.php?t=11229&hilit=RecycleBin#p43279
You can change deletions to be permanent instead
