Created files have creation date in 2052
wpwoodjr
I'm syncing files to my Android phone's SD card from my Windows 8 VM running under Parallels (OSX) and the files that are created there get created with a date between Feb 19 2052 (tomorrow) and June 2052. When I copy files using Windows Explorer the date is Feb 18th (current time). The modified date is the same as the modified date on the original file.
This seems like it is probably a bug in FFS?
wpwoodjr
Even the synch.fss_db file has a creation date of 2/25/2052 8:30AM
wpwoodjr
Even weirder, if I copy files to the SD card from Windows explorer, then check the creation date, it is the current date/time. Then if I run FFS and do just a compare operation, the creation dates of the files are changed to 2052.
[404, Invalid URL: https://sourceforge.net/p/freefilesync/feature-requests/235/]
wpwoodjr
Why does the date get changed when doing a Compare?
