File copied to Google Drive in Log but not on Google Drive
illahee
I'm new to this product. I have a RealTimeSync running that moves files to OneDrive. I have a FreeFileSync process that copies the OneDrive folders to Gsuite drive weekly only.
OneDrive seems slow sometimes to save files that I'm working on, and thought I might try using the Gsuite weekly folders to compare.
A file I worked on Friday 10-4 shows being copied (I think) to the Gsuite drive with this log entry I'm saving. This log only has one entry for this filename. The log from today shows:
5:00:32 AM Info: Creating file "gdrive:\ricks@afts.com\Contracts-CPI\CalVET\23520510 A1 - Payment Processing Services SOW - CPI Signatures.pdf"
I would think at 10 a.m. on the 5th I should find this file in my Gsuite Drive folder, but don't.
This process runs as a batch job using Windows Task Scheduler.
Any thoughts on how I can fix my setup or figure out why the file is not being saved when it seems like it was in the log at 5:02 am.
Thank you.
After comparison, you can double-click on any file to open it in a file browser. For Google Drive files, it will show them directly in the browser.
