NEW FEATURE : S3 Protocol Access
UbyOne
You already enabled the connection to "GoogleDrive" and hey men, it is really great - many thanks!
Do you plan to connect S3 CloudService (S3 Protocol) too?
UbyOne
news on S3 connector?
None
John1234
Hi @UbyOne
Try this free cloud drive mounting program. It will let you mount S3 cloud so you can use it with FFS.
https://www.airlivedrive.com/en/
UbyOne
HI @John1234
thx for your reply!
I already found a similiar product:
https://www.callback.com/s3drive
but I should admit your suggestion is better!
Anyway unfortunately it doesnt solve the problem ...
At this point I think it is a limitation in S3 resources/protocol; I try to explain you.
As TestCase I use 2 existing files in my local directory, they are NOT pesent in S3 (mapped as a drive):
File DateCreat DateMod
aaa.txt 08/04/2024 16:17 13/02/2025 18:00
bbb.txt 08/04/2024 16:18 13/02/2025 17:55
(sorry no image: I didnt manage to add it ...)
FFS execution:
correct: local ->+ s3
now in s3:
aaa.txt 13/02/2025 18:28 13/02/2025 18:28
bbb.txt 13/02/2025 18:28 13/02/2025 17:28
you can see a new timeStamp is added both as "created" as "modified".
I execute again FFS:
wrong: local <- s3
that is because the "date modified" s3 is newer than "date modified" local.
with "normal" storage (as local directories) that doesnt happen, so I strat to think is something in s3 protocol ...
what do you think?
So, S3 or the protocol the tool you use to mount S3 does not support retaining dates.
If you only need to sync local => S3, you could use the Update sync variant, instead of the Mirror variant.
If you also need to sync local <= S3, then you need to find another method.
