CocoaError 3328: on a shared networked drive???
jainraje
I'm seeing this error recently:
Many things changed. New MBP, new macOS, etc. I'd like to get rid of this error.
The recycle bin is not available for "/folder1/folder2/folder3/folder4/file1.txt".
CocoaError 3328: “file1.txt” couldn’t be moved to the trash because the volume “macFUSE Volume 0 (sshfs)” doesn’t have one. [NSFileManager::trashItemAtURL]
Ignore and delete permanently each time recycle bin is unavailable?
Can the recycle bin be added to the folder in question?
Thx,
jainraje
Recycling is typically not available for network locations.
Going into the sync settings and change deletions to 'permanent'
jainraje
thx for prompt response.
