Folder for recycling on the ftp server
chrisfoo
I have found a trick, if you copy a valid specification for an FTP server from the target input to the recycle bin folder input, it will be created on the server.
Maybe it helps someone.
That's just normal behavior. You can select any folder for versioning, doesn't matter if local, (S)FTP, MTP, or Google Drive: https://freefilesync.org/manual.php?topic=versioning
