mtp long time
when synchronizing from mtp (cell phone) to pc over usb cable, it takes a few seconds until I see 100% done,. Then there is the dialog for 45s until message that all is done. My idea is that its about creating app-file sync on mtp storgage. Consistent with this, when I sync from pc to mobile, it takes a few seconds to load about 10%, and then 45s to load 100%.
I saw these hangs when trying to rename a file on some MTP devices. For whatever reason the smartphone gets freaked out and blocks for 30 seconds, apparently doing nothing.
To verify you could test disabling the DB file (which renames the file sync.ffs_tmp to sync.ffs_db).
Yes, this helps.
Now I have found that I have to turn off Fail safe copy in Tool Options. Now it takes few seconds to sync.
