Can't sync files with QAT extension
goldriverbob
I want to sync my Office customizations. They are in files with the officeUI and QAT extensions (for ribbon and quick access toolbar changes). Using the path and a filter for word.* the officeUI is included in the backup but not the QAT. Similarly, if I filter with *.qat and *.officeUI, I only get the officeUI files in the sync. I don't want to back up everything because there is so much in the subfolders that I don't want.
Are these changes you are making in the include filter?
Can you provide a screenshot of these filters?
Perhaps these *.qat files are locked by MSoffice as long as any MSoffice application is open.
Try closing ALL MSoffice applications and then run your sync.
Conversely, you can try using VSS.
goldriverbob
@xCSxXenon I don't see a way to post a screenshot, I'm using the Filter tab in the Synchronization Settings dialog. It has two rows in the Include text box:
*.officeUI
*.qat
I also tried them in the reverse order. The officeUI files are synchronized. The qat files are not synced.
See: viewtopic.php?t=11025&hilit=attachments#p42261
