Cannot sync directories
rayanik
Hi, I have been using FFS for quite some time. I have a D drive and an E drive. I use the UPDATE E drive synchronization which has been working well. For some reason I haven't been able sync over the last couple days.
Below is the log.
If anyone can assist, it would be much appreciated.
Thanks.....
4:05:26 PM Warning The following items have unresolved conflicts and will not be synchronized:
Folder pair: D:\Karim <-> E:\Karim
My Documents\Fax\Drafts\desktop.ini: Both sides have changed since last synchronization.
My Documents\Fax\Inbox\desktop.ini: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Changelog.txt: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\FreeFileSync.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\RealTimeSync.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\User Manual.pdf: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Bin\FreeFileSync_Win32.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Bin\FreeFileSync_x64.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Bin\RealTimeSync_Win32.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Bin\RealTimeSync_x64.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Resources\Animal.dat: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Resources\cacert.pem: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Resources\Icons.zip: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Resources\Languages.zip: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Resources\Registered.dat: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Uninstall\unins000.dat: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Uninstall\unins000.exe: Both sides have changed since last synchronization.
My Documents\FreeFileSync_11.6_[Donation_Edition]_Windows\Uninstall\unins000.msg: Both sides have changed since last synchronization.
My Documents\OnScreen Control\ApplicationPositionSetting.txt: Both sides have changed since last synchronization.
My Documents\OnScreen Control\LG HDR WFHD_11920_391917\OSCAppPosList_LG HDR WFHD_11920_391917.txt: Both sides have changed since last synchronization.
My Documents\Outlook Files\My Outlook Data File(1).pst: Both sides have changed since last synchronization.
My Music\iTunes Media\iTunes Library Extras.itdb: Both sides have changed since last synchronization.
My Music\iTunes Media\sentinel: Both sides have changed since last synchronization.
My Pictures\iCloud Photos\desktop.ini: Both sides have changed since last synchronization.
My Pictures\iCloud Photos\Photos\00871a57-52f2-4adf-a985-6ac1a9b437c0.mp4: Both sides have changed since last synchronization.
[...] Showing 25 of 148 items
4:05:26 PM Info Synchronizing folder pair: Update >
D:\Karim
E:\Karim
4:05:26 PM Info Deleting file "E:\Karim\My Pictures\iCloud Photos\Photos\0ebd6eb7-820e-47f5-9f5b-473bb0ce80c8-ba49.ffs_tmp"
4:05:26 PM Info Creating file "E:\Karim\My Pictures\iCloud Photos\Photos\002fc3b4-c269-47a9-903c-aa101c0a1eea.jpg"
4:06:27 PM Error Cannot copy file
"D:\Karim\My Pictures\iCloud Photos\Photos\002fc3b4-c269-47a9-903c-aa101c0a1eea.jpg" to
"E:\Karim\My Pictures\iCloud Photos\Photos\002fc3b4-c269-47a9-903c-aa101c0a1eea-9d2d.ffs_tmp".
Error code 0x1aa: The cloud operation was not completed before the time-out period expired. [CopyFileEx]
4:07:32 PM Info Creating file "E:\Karim\My Pictures\iCloud Photos\Photos\0ebd6eb7-820e-47f5-9f5b-473bb0ce80c8.jpg"
4:07:32 PM Error Cannot copy file
"D:\Karim\My Pictures\iCloud Photos\Photos\0ebd6eb7-820e-47f5-9f5b-473bb0ce80c8.jpg" to
"E:\Karim\My Pictures\iCloud Photos\Photos\0ebd6eb7-820e-47f5-9f5b-473bb0ce80c8-54e0.ffs_tmp".
Error code 0x185: The cloud operation was unsuccessful. [CopyFileEx]
4:07:33 PM Info Creating file "E:\Karim\My Pictures\iCloud Photos\Photos\1913f616-b0d4-4966-b54a-b9dffb9ac495.jpg"
4:08:35 PM Error Stopped
therube
tnmenon
I have the same problem. A couple of files are not being syncd as error "both sides have changes since last synchronization" keeps coming up, though only one side has changed. How to manage this?
Run a comparison and tell FFS what to do with the conflicts. iCloud issue seems like a connection issue. Do you get the same message about the same file(s) in iCloud?
tnmenon
Thanks for the response. When I ask to ignore, it ignores always, resulting in failing to sync the files
Ignoring isn't telling FFS what to do lol
Tell it which version to keep
