Nice program and works ok,
but how to remove that annoying sound after syncronization?
Disable notification sound
You need to take the time to search the forums before asking questions. Many of these are already answered. viewtopic.php?t=2060&p=8796#p8796
Oh, thank you. I tried to find but did not find.
By the way I thought about removing the audio file but was frightened that the program would be work wrong.
I think there should be option for switching off sounds.
New with FreeFileSync 10.13: notification sounds are managed via the global options dialog
