When developing advanced "multi folder pair" projects turning a folder pair on or off comes in handy for tetsing pruposes.
Order matters - especially when commands are executed on error/success/completion.
A prior-ranking folder pair for the sake of an example might mount a virtual disk which constitutes a "folder dependency" for a lower-ranking folder pair.
Ignore a folder pair temporarly until all dependencies are reliably met under diverse circumstances.
The feature is useful when working with more advanced scenarios and easy to implement.
Either a ceckbox, or graying out the textfields.
Overlaying a cross on the filter icon is an elegant option. No change in secreen space. Toggle it on or off. Please - do it - so easy - so useful.
New feature: Ignore folder pair checkbox in multi folder pair szenarios
