I installed this program a couple of weeks ago to create a local backup of a network directory. I decided it was unnecessary and uninstalled the program. Even still, the folder which had been previously configured to mirror for backup keeps popping back up after repeated deletion. I remember a sync service has also been installed and thought maybe that was my issue.. it was not.
As far as I can tell, there are no processes, services, or tasks scheduled that would be causing this. A fairly minor issue, but obviously some sort of error occurred in the uninstall process. I re-installed to see if config files were somehow missed in the uninstall, it loaded as if the program was brand new to this machine. It did not seem as though there were any, as the basic (default) configuration loaded on initial run - no folders selected, no additional options checked/selected, no schedule configured to run.
Any suggestions??
Program uninstalled, but sync will not terminate
Is FreefileSync or RealTimesync in your task manager?
Or Scheduled Tasks?
