I noticed that whenever I use FFS my computer gets really laggy, slow. Even after the app's done I often need to reboot so I can get my regular speed - and my PC is brand new and far from low on resources.
I'm trying now using RealTimeSync and it's the same thing. Is there a way to tweak the app to use less resources - even if that means transferring slowly or something?
Resource use management
RealTimeSync should use essentially zero resources or CPU time. You have a fundamental computer issue if RTS is causing an issue. Open Task Manager while running a sync and monitor the CPU/RAM/DISK/NETWORK usage of FFS specifically and the overall total. If any are 100% while FFS is running, that is your bottleneck
You could try if setting the RunWithBackgroundPriority flag to "false" helps.
It's already as false by default.You could try if setting the RunWithBackgroundPriority flag to "false" helps. Plerry, 28 Nov 2024, 11:14
The weird thing is that the PC gets laggy, but when I check disc and CPU usage, they are absolutely normal.RealTimeSync should use essentially zero resources or CPU time. You have a fundamental computer issue if RTS is causing an issue. Open Task Manager while running a sync and monitor the CPU/RAM/DISK/NETWORK usage of FFS specifically and the overall total. If any are 100% while FFS is running, that is your bottleneck xCSxXenon, 27 Nov 2024, 22:22
Sorry, my bad. That should obviously have been:It's already as false by default. tsavkko, 28 Nov 2024, 11:22You could try if setting the RunWithBackgroundPriority flag to "false" helps. Plerry, 28 Nov 2024, 11:14
Try setting the RunWithBackgroundPriority flag to "true".
Note that this flag is a FreeFileSync (FFS) setting, and does not affect RealTimeSync (RTS).
So, it only takes effect while an actual Compare and Sync are running, not during directory monitoring via RTS.
