Moving Files Either Left or Right with the mouse in real time?
Jupiter
Hi All,
I am sharing my thoughts here!
I don't know if it's a feature request,
or if I have missed something with FFS.
I would like to be able to quickly click on
either the left or right hand column listing and drag/copy
the file either way and see it move in real time on the screen?
The image you share shows the Compare results window.
For each item it shows you the intended sync action.
The only thing you can do in this window is modify the intended sync action per item, or via a right-click e.g. add items to you Include or Exclude Filter.
You can not drag items left-to-right or vice versa.
For that you need a file manager, like the Windows File Explorer,
not a Synchronization program like FreeFileSync.
Jupiter
@Plerry, Thank you for the info
You can highlight items and hit the ENTER key or right-click -> Synchronize selection
