Syncing problem
tnmenon
While syncing, error message shows up that both source and target files have changed after last synchronization, though only the source file has actually changed. Can anyone please help me resolve this? Thank you.
If you have a source and destination, you should probably switch from two-way to mirror sync. These conflicts mostly show up when using two-way. If you do need two-way, something is changing on both sides and FFS doesn't want to erase data, you'll need to determine what is causing the file to change.
tnmenon
Thanks for the response. It worked when I switched to mirror. To solve the issue in two-way sync, can I delete the target file and then re-create it through mirror sync and thereafter work with two-way?
I guess that would work...
tnmenon
It didn't :( Had to go back to Mirror option
