The name "sync.ffs_db" is used by ...
JoePass
I use google drive to synchronize. I installed FreeFileSync to another comp and made the same synchronization for the same folder. Then appears the following errors
Cannot open file "gdrive:\xxx@gmail.com\sync.ffs_db".
The name "sync.ffs_db" is used by more than one item in the folder.
Cannot read file attributes of "gdrive:\xxx@gmail.com\sync.ffs_db".
I found the following solution viewtopic.php?t=10126. It works well, but if I restart RealTimeSync, the same errors appear again and I have to delete these files .sync.ffs_db in Google Drive. How to solve this problem for forever?
