Problems with parallel files option
After updating to version 13.8 at the same time as updating Windows 24H2, if I set a number greater than 1 in the parallel files option of the destination folder, the program reads double or triple the files present and moves files randomly in the directories or deletes or even does not see files present, updated to 13.9 the problem persists, with Windows 22H2/23H2 it works regularly with a number greater than 1 of parallel file processing. Does anyone have any suggestions???
Kind of sounds like your folder pairs &/or filters are causing an overlap condition?
Post same (along with sync type).
Were you using 13.7 prior to updating to 13.8?
Yes of course, what would you like me to post?
settings 1 > 4
I tried with 1>3
1>2 same
Yes but only with windows 24H2 bastard
settings 1 > 4
I tried with 1>3
1>2 same
