I have the "Configuration" (Last session) panel on the left from where
I choose the jobs.
There are about 60 entries.
And I have to use FFS V5.6 to use it this way.
Every new version since 5.6 cuts the entries in the config panel.
I use FFS in portable mode, but I also tried the "local" installation.
There is no difference.
To reprocude this bug, do the following:
- Add more than 30 (*.ffs_gui) entries to your config panel.
- Close FFS
- Open FFS again and count the entries, there will be only 30.
I am very happy with FFS and I normally wait for the next release,
but this bug seems never been recognized.
Thank you
Hannes
Configuration files limit to 30?
The maximum number of entries can be set in GlobalSettings.xml:
<ConfigHistory MaxSize="30">
Thank you.
I'd never guessed that.
Are there more secret setttings?
