I would ask you for help, how to do it.
I have two folders. In first there are jpg files - name DocumentXXXX - (XXXX means number) and in second folder there are same name files but pdf format.
I want to compare these folders and show only files (according to only file name), which arent in the both folders instead of file format (extension).
How I can do it please?
First step I did like on the picture (exclude *.pdf, *jpg).
Could you help me please?
compare two folders - show only files what arent in both
FreeFileSync (FFS) only compares identically named files, including extension.
So, it seems FFS is not the tool for your use-case.
Just pointing out...
(On the Windows end, with other tools) you can do stuff like (& while not necessarily specific to above, above very well like can also be done), Finding files with .MD5 files with them.
