Three copies of .sync.ffs_db
JoePass
I use google drive to synchronize. I installed RealTimeSync to another comp and made the same synchronization for the same folder. Then appears the following errors
Cannot open file "gdrive:\xxx@gmail.com\sync.ffs_db".
The name "sync.ffs_db" is used by more than one item in the folder.
Cannot read file attributes of "gdrive:\xxx@gmail.com\sync.ffs_db".
I found in this folder in Google drive 3(!) copies of file .sync.ffs_db. It is the reason for this error. How can I solve this problem? In another comp I used another SyncSettings.ffs_batch file. May be this is the reason and I have to use single SyncSettings.ffs_batch for all comps?
JoePass
There are no suggestions?
