Before I install it, I would like to understand how I can uninstall the app completely, I tried to search on the FAQ and the forum but couldn't see anything related. Hence looking for advice.
OS: MacOS 15.1
Sam
How can I uninstall FreeFileSync completed on my Mac?
MacOS is dumb so there are two ways it could be. With FFS open, the top bar should have context menus, and one of them might be "Help". Sometimes you click "Help" and there is an uninstall option. Another way I've seen is to simply drag the program from the application list to the trash can.
