Move filesync to new server
sdeeley
We use filesync to sync files between 2 servers, we are replacing the source server and maintaining the timestamps on the files we are migrating to the new server. What is the best way to move the filesync settings from old to new server and what should I make sure that the filesync runs the same as it did on the old server?
Copy/paste the sync configuration you saved and set up the new server the same way the old one was
