I sometimes manually delete files when using FFS to compare two folders, whether by right-clicking on the filepath and choosing "delete" from the dropdown menu, or by clicking on the filepath and hitting the delete key.
A dialog window pops up to confirm deletion, and by default the file is sent to the recycle bin.
For my workflow, I prefer to fully delete these files, rather than send them to the Recycle bin. So, I would prefer to set that box unchecked as my default.
I've looked through FFS options, and web-searched about this question, and can't find any way of setting that option unchecked by default. Is there any way to do this?
Thanks.
default-uncheck Recycle bin on manal delete?
Use Shift+Delete instead of only the Delete key.
@kriebie thank you, that will fit easily into my normal workflow
