Avoid countdown before comparing?
dirk-o
How could I avoid the countdown before comparing? And why is there one when there is one sync / comparison at the same time?
srjones67
What countdown? I click compare and FFS starts its scan comparison.
dirk-o
The countdown shown on the left side in the address bar where the folder path is shown at the top. Usually shown only - as far as I know - when another sync / compare is active using the same folder(s).
