How can I start FreeFileSync without a synchronization preview?
Backupper
I know it can be dangerous without having a look at the synchronization preview before actually starting the synchronization process but I would still like to know whether it is possible to execute one or more FreeFileSync synchronization profiles without having to look at the synchronization preview before it actually performs the synchronization, i.e. I would like to be able to run it in an unattended mode.
Is that possible? I was looking for such an option in the profile settings and the options but could not find it.
Backupper
Thank you for the help and the quick reply.
That works. If you still want to manually trigger it, saving the sync as a .ffs_batch configuration and double-clicking that file directly should also work
