Error, after my harddisk removed, cant not be deleted sync file
barikinil
I want to learn what the problem is about sync file. I have an issue with my old hdd, and and i remove the hdd for a while. program give me warning about, target not found, and i remove batch sync setting file another location temporaly. But this time the program warn me about file not found. there is no sync file but program searching old sync file.
how can i pause or stop the sync file. the program continue searching the old sync file after deleting.
can we pause the process, without deleting the sync file.
Thank you.
It seems you are using the "Use database file to detect changes" option in your Synchronization settings (F8). If you change the left and/or right base location there may not yet be a database file in that modified location. Such database file is created at the end of the first FFS sync involving that location.
barikinil
yes i have done this once, but deselect that option. error didnt dissappear.
