Quitting/Exiting from the tray icon's context leaves the process running
jackdinn
Well the title says it all pretty much.
Maybe you are aware but i didnt find anything when searching.
Im on manjsro KDE, when you try to close/quit the realtimesync via tray icon context menu quit the icon disappears but the process are all left running.
❱ps aux | grep -i realtime
greg     1454194  0.0  0.0    232     0 ?        Ss   11:26   0:00 /opt/FreeFileSync/RealTimeSync
greg     1454197  0.0  0.1 402168 57972 ?        Sl   11:26   0:00 /opt/FreeFileSync/Bin/RealTimeSync_x86_64
greg     1456726  0.0  0.0    232     0 ?        Ss   11:34   0:00 /opt/FreeFileSync/RealTimeSync
greg     1456729  0.0  0.1 401688 58228 ?        Sl   11:34   0:00 /opt/FreeFileSync/Bin/RealTimeSync_x86_64
greg     1457390  0.0  0.0    232     0 ?        Ss   11:36   0:00 /opt/FreeFileSync/RealTimeSync
greg     1457393  0.2  0.1 402168 58172 ?        Sl   11:36   0:00 /opt/FreeFileSync/Bin/RealTimeSync_x86_64
greg     1458866  0.0  0.0   6400  3700 pts/2    S+   11:40   0:00 grep --color=auto -i realtime
Fixed! Good observation. I'm wondering why this wasn't reported earlier.
https://www.mediafire.com/file/pcb37w8nz5htcxy/FreeFileSync_14.1_Linux_beta.tar.gz
jackdinn
Well, I suppose most people just assume that when the icon goes, it would/should follow that the process has gone with it. I just happened to be doing something else at the time and spotted a whole cluster of ffs threads running. So i tinkered with it and see what was happening.
Glad its was prob an easy fix for you rather than i PITA kinda fault :)
jackdinn
Oh, i just donated to get the multi thread bandwidth and it only has the 14.0 download. Do you happen to have the 14.1 version that you gave a link to yesterday?
Many thx for the work put into this app.
Cheers.
Cheers. jackdinn, 23 Jan 2025, 20:47
That's just a beta so you'll have to wait for 14.1 to hit full release
jackdinn
Np, i can just keep in mind that the try icon acts as it does atm. Not a problem
Cheers.
