Checking to see if these settings are correct.
Samir
Hi all!
First time user of FFS and wanted to check if I'm doing this correctly.  I've made a mirror of a hard drive using FFS.  HDD-original = H://, HDD-mirror = I://.  What I want to do is compare H:// (which is active) to the passive mirror and then have the differences between them saved to a separate mirror update drive (let's call it J://).
So far, I've used the synchronization feature with the original (H://) on the left hand side and the mirror (I://) on the right hand side.  I'm using "update" as the synchronization method (please see enclosed) where new items are copied to the right side and rugby side items are updated. However, I need these updates versioned and saved to the J:// instead (which I think I'm doing by adding the J:// under, "move files to user-defined folder"). However, no new offers are being created.
Should I only new creating new? Or only updating? Should I be decreasing the time to 30 days and backing it up monthly?
Your help is greatly appreciated!
Thanks!
As far as I know, there is no file system or OS that uses double slashes for local paths. Change everything to single slash and see if that works
FreeFileSync (FFS) does only perform (automatic) sync actions between the left and right locations it compared.
So, FFS cannot to compare H:\ with I:\ and then (automatically) "sync" the differences to J:\.
You can however do it manually.
The sync configuration in your screen-shot would copy every file that gets deleted or updated by your FFS sync to J:\ , thus retaining one or more previous versions of such files.
That is different from syncing the difference between H:\ and I:\ to J:\
