Hello all, I routinely sync between 2 drives with FFS. However I've changed some of the folder layout, and tried checking off "Detect moved files", but it still wants to delete and copy the same files over. How do I work around this issue?
Thanks in advance,
Anytimebro
Detect Moved Files
You have to perform a single sync after checking that box. Subsequent syncs will use the generated db file to track the changes
