Hi Guys
Just downloaded and set up the system
From internal HD to external HD > mirror
Problem I get this message
ERROR_NO_SUCH_DEVICE: A device which does not exist was specified.
Things were working for about 30 minutes then this message with an error. I marked ignore then the next and the next. 1000's of errors came up and if ignored all the backup was finished?
Some folders and files were copied but 96% of them were not as it gave a 4% completion.
Hopefully, somebody can point me in the right direction to sort out this issue out
Thanks in advance
Newbie Problem- Can You help me? ERROR_NO_SUCH_DEVICE: A device which does not exist was specified.
Sounds like one of your drives dropped out/connection. Could be failing, could be the power cable, could be the data cable, could be many things
Thanks for the reply. It's a brand-new drive (external) and it worked well for about 30 mins. then this issue. It's had no problem with other programs backing up. Like EaseUS Todo Back up. It backed up with no problem so I find it hard to believe it's the drive dropping out. Could it be something else?
Did you (content) verify that other backups backed up correctly.It's had no problem with other programs backing up.
(At least on a sampling of files.)
It could be the internal drive as well. The error is specifically saying the location doesn't exist, so the only option is that something in the chain is failing, usually hardware with such an error
