is FFS torjan ? I observe strange sympton
billyn_hk
I installed FFS on 2 computer with windows 10, and observe there is unknown device appear in network neighbourhood, but while I was carefully having a closer look, it disappeared.
I found other ppl also mention about this strange symptom,
the similar situation happens on both computer, and after uninstall, the sympton disappear.
The program feature is good, and I was originally preparing to give donation but has had turned down.
I decided to quit using. Moreover, I discover it state it is open source, so where is the source code of program ? I cannot find it.
correct me if am wrong.
Regards
billy
Code is in the download section of the website. I don't believe FFS is malware. You can always upload any suspicious files to VirusTotal for extra evaluation. FFS wouldn't have the ability to cause a device to appear on your network, so that is unrelated.
therube
What version of FFS?
What OS?
Where did you download FFS from?
What country are you in?
Provide a hash of your downloaded file.
Where?
