Deleted files due to mirroring. How to recover?
Randomuser237648
Need some help. I mistakenly set the synced to mirroring instead of updating the drive and it deleted over 8tb worth of pictures and videos. FAQ said there is an undelete tool but where is this tool or function? I also went to a data restoration company and I'm not positive they are able to find them. Any help would be great appreciated.
The obvious answer to your question is: from your backup.
But it seems that, like many before you, you now learned the need to have backups the hard way )-:
As far as possibly still being able to recover your data:
It depends on how you have set your "Delete and overwrite" option in your FreeFileSync Synchronization Settings (F8).
By default, this option is set to Recycle Bin, so that may then be the place to look.
However, you lost 8tb of data, which may have been too much for your Recycle Bin to hold, depending on your OS settings.
The FAQ mentions using a tool but doesn't mention any specific one. These tools are very unlikely to work. They don't work with SSDs, as those trim themselves very frequently. With HDDs, it's more likely but still very slim ,and the choices are riddled with endless scams and fake software. A data recovery specialist is the best chance, but also the most expensive. As a data recoverer, I would be wary of any local place as destroying the remaining slim chance of recovery is very easy.
Ultimately, as Plerry said, restoring from a backup is the only real answer to this question.
Randomuser237648
However, you lost 8tb of data, which may have been too much for your Recycle Bin to hold, depending on your OS settings. Plerry, 29 Jan 2025, 08:46
Unfortunately, the drive and it's files is on a separate HDD and my primary drive where the recycle bin is on the main SSD. Would the files be on the separate HDD recycled bin?
If your separate HHD is a NAS:
Some NAS-ses allow you to configure network shares for its files to be deleted to an internal Recycle Bin, as opposed to being deleted permanently (moved to dev/null).
If applicable, FFS is blissfully unaware of this NAS feature and thinks there is no Recycle Bin available.
You would need to login to you NAS (commonly as admin) to recover such "deleted" files.
