Is there an easy way (without having to replace the FFS sound after each update) to always use an own file sounding when the comparison has finished or can I make the FFS sound play after finishing (doesn't seem to play) or make the sound (without increasing the loudness generally) louder?
The sync sound is played and loud enough.
No comparison finishing sound?
"Compare_Complete.wav" is just an empty sound file that needs to be replaced if one wants a notification after long comparisons (probably binary).
Ah, thank you Zenju,
Very strange, I actually mean to remember there was a time this wav sound really sounds. And the finishing sound does really sound, if I am right. That's odd.
Is there an easy way (without having to replace the FFS sound after each update) to always use an own file sounding when the comparison has finished?
Thanks again.
Thanks again.
New with FreeFileSync 10.13: notification sounds are managed via the global options dialog
