Error o x 185
Good afternoon, when I try to make a copy of a folder from the computer to the external hard drive I get an error (I attach screenshots). I omit and it seems that the copy is correct. Can this problem be solved? Thank
There isn't a screenshot to look at
There isn't a screenshot to look at xCSxXenon, 11 Feb 2025, 18:26
- Captura de pantalla 2025-02-08 18.04.17.png (237.02 KiB) Viewed 2478 times
Translates toa cloud error. You likely don't have the file downloaded locally. The file "exists" so it can be used, but it gets downloaded in real-time. FFS can't sync it because the file itself isn't stored locally yet. Check your DropBox settings for a setting to download all data locally
Thanks a lot
