Warning message gAMA
teymur_bagirov
Hi, starting version 14.1 one workstation (W7, 32 bit) produces warning message "gAMA gama value does not match sRGB"). Rollbacked to 14.0 - no problem. Installed/Uninstalled several times.
Just for your information.
What about FreeFileSync 14.2?
teymur_bagirov
14.1 and 14.2 both produce same notification on that W7 pc.
But I've tested on another VM with W32 - there is no warning message.
Difference between them is in the locale. The first one is Russian, VM is English.
If you remove item_copy.png from <FreeFileSync install directory>\Resources\Icons.zip", does the warning go away?
teymur_bagirov
Yes, app with Icons.zip wthout item_copy.png is opening without this warning. Thank you.
Thanks for confirming. Will be fixed in the next release.
teymur_bagirov
But already twice App crashed and produced dump file FreeFileSync_Win32.exe 14.2 CrashDump 2025-02-23 185807.dmp
So, i have to rollback again.
Waiting for next release.
