Log when comparing by file content shows very small "time elapsed"
diegopau
Not sure if this is intended or maybe a small thing to fix. After doing a very long Compare by File Content operation, that took 6 hours and 22 minutes, I was a bit confused initially by the log info showing "Time elapsed: 00:00:01", and also it seemed to show me a timestamp belonging to the moment I started the process not the moment it ended. So I actually thought for a moment that the 6 hours I waited for it to complete were discarded and it was showing me the log for a previous 1 second long comparison, but then in the top part of the log clearly says 6 hours 22 minutes. You can see this in the image attached.
This is in version 13.9 but I just installed 14.2 and I did a small test with a small folder and I see the same behavior.
Next version will make this more clear:
diegopau
Thank you!! that completely solves any possible confusion.
