Onedrive to SFTP.
ivg
I would be grateful for any ideas to solve the mystery.
I'm comparing files between Onedrive and SFTP.
I'm getting strange results, the files are missing on the SFTPside, but FFS says I shouldn't copy.( show files thet won't be copied) see picture.
Swap slide - in principle a good result bud strange results.
Setup - File size (file time + size) -> Update
You are using a database with the "update" sync method. Since these files have been deleted from the "destination", they are tracked in the database as so and don't get re-copied. Try turning that option off in the sync settings
John1234
Are you using OneDrive software that comes with Windows to access the files in ffs?
The only way to get this to work properly is to make sure that 100% of the files on OneDrive are synchronized locally. There is a better way.
You can mount onedrive as a cloud drive to a letter in Windows. Then use ffs with that drive and you should get better results.
Two apps you can try:
https://www.airlivedrive.com/en/
This is a gui app.
Or, you can mount onedrive with rclone to a drive letter or folder.
