I would like to have a new context menu item added to the Overview window to open folder.
"Show in Explorer" is already present on folder pair control but it would be nice to have it in the Overview window.
Add context menu item in Overview window to show in Explorer
Each line item in the Overview panel corresponds to a folder pair, so this wouldn't be possible. Just as easily, you can select the item(s) in the Overview panel, which will highlight them in the comparison results, and then perform this action from the results directly.
Given that you already have a 'Show in Explorer' context menu item available within the Results list, fail to see why something like that couldn't (simply, he says ;-)) be expanded to also include the Overview items?
Thank you for your response.
At the point I would like this new context menu I am only only populating one of the two folder pair to use this app to highlight were I have large directories.
I understand now why this would be an option for the normal use of the app to sync.
