Regarding working with folder pairs, for example, I have 5 pairs registered and I would like to synchronize only one pair. Is it possible?
Please tell me how to operate it
About folder pairs
See viewtopic.php?t=10905#p41684 and below
Thank you.
But honestly, this method is troublesome.
I would like you to attach the ON and OFF check buttons for each pair. Please consider it.
I'm very new to FFS, but the method I'm using (for better or worse) are the local filters, which you can set for each pair.Thank you.
I would like you to attach the ON and OFF check buttons for each pair. Please consider it. aristo5555, 28 Feb 2025, 09:30
If I want to "disable" syncing a pair, I click on the local filter (found in the center between the two gear symbols) and add a wildcard to the exclude section, thus excluding every file. To reenable syncing for that pair, I right-click on the local filter and select "Cut", which removes that filter and the file exclusion.
As far as I can tell, this works pretty well and is reasonably quick to toggle.
@tangofan
A creative solution!
As you can see, there is often more than one way to skin a cat ...
