Feature request: save 'Compare' results so it could 'Synchronize' later.
PiuksPauks
As the topic says, it would be nice to be able to save Comparison results so it could be synced later.
This will lead to any changes occurring between the time of comparison and syncing being missed, possibly leading to the deletion of important data. That sounds like a bad idea, what scenario would justify otherwise?
PiuksPauks
Ok, fair enough.
In my scenario, i would like to save comparison results so i could analyze manually why some items did not sync...
Maybe allow to save comparison results and load it, but disable syncing?
You can export your FFS Compare results via the FFS main menu Tools / Export file list, and analyze that list manually.
However, there is no option to import such list.
PiuksPauks
Thank you, will use that option.
Ok, fair enough.
Maybe allow to save comparison results and load it, but disable syncing? PiuksPauks, 02 Mar 2025, 08:35
Isn't that what the logs are for?
