Hi Everyone, I have a reasonable size Forum that I backup everyday.
I need some software that will download via SFTP to my local machine and then Presumably another process to mirror it to a backup forum. There are currently around 17000 files.
I have software that currently downloads to my local machine but I need to upload it again to the Backup site. It would be great if the one piece of software could do both.
Many Thanks and Best Regards,
VYodaCoda.
Does/Can The Software Preserve Last Modified Date With SFTP
The software (FreeFileSync) can/does preserve the last modification date, provided the protocol and the server you use support it.
Older flavours of SFTP often do not; most modern flavours of SFTP apparently do.
You can simply test it for your case with one or more test files and folder(s).
Good Morning Plerry,
Many thanks for your excellent reply.
I will give it a try.
Best regards,
Vyodacoda.
Best regards,
Vyodacoda.
