I just auto updated FFS and now when i run RTS it first shows a dialog after syncing which before it didnt. It was completly silent.
And when i create a new folder in a project folder that i have setup for realtime backup it just gave me an error about the folders being significantly different and gave option to cancel, switch(why?) and ignore.
So basically it works not as it did.
What can i do to fix this?
Thanks,
mlon
RealTimeSync_Error after updating
Ok, i managed to surpress the warning messages and it looks like it works silently like it did but
i do not remember these error/warning messages before and also the dialog after each RTS action.
Eh.. it looks like it also puts deleted files in my versioning folder now which before it did not and just deleted the files.
When i now delete a file within a folder RTS creates a filestamped file in my versioning folder including the folder i deleted it from.
Is this a feature?
Is this a feature?
Been a feature for years and isn't related to RTS, but rather your FFS configuration. FFS doesn't change anything on its own, so somebody was clicking in the configurations settings
